HI to all..
for a long while now I've had a stalling problem I went allover different forums trying to find a solution. Tried many fixes like cutting the cover screws on the ECM in half or tying the cable harness. And did not work.
So after a LOT of trouble shooting fond that the screws the hold the cover would get loose after a while causing the cover to vibrate more then normal this created a false connection condition. the would cause the stalling.
(I should mentinon that my ECM has aconector on the inside of the Cover).
So my solution that has been working for more that a week was to fill rhe holes with Loctite THREAD LOCKER BLUE 242 then used a hot air gun to speed up the drying process and got new screws that were the same lenght BUT bigger diameter.
hope this helps some else.
NOW A CAN CONTINUE TO FIX OTHER PROBLEMS. LIKE THE WILL NOT ACCELARATE IF i PRESS THE GAS TO FAST i HAVE TO PRESS IT SLOWLY.
ANY IDEAS FOR THAT ONE?
THANKX=S
THANKX=S
