If you've read I changed my oil guage sender about 5 weeks ago (96 XJ 4.0) and the leak had stopped. Now I have a new leak coming from the base of the fitting that the sender screws into on top of the oil filter adapter. I really didn't apply much pressure taking the sender off and on so don't think I cracked it.
Does this fitting use an o-ring or gasket ? Can I use an adapter fitting in it's place ? I have plenty of wire to do it. Don't know why the factory didn't just screw it in and not use a fitting.
Guess it just takes an engineer to F*** something up and someone that knows what they're doing to fix it.
