thedevil1236
I have a 2000 Jeep cherokee and am having a problem figuring out how to get the oil pan off.  I believe my oil pump isnt working correctly and i am running low oil pressure.  at idle, the oil pressure drops off completely at times once the engine is warmed up.  if its the main bearings to blame, then ill still have to remove the oil pan anyways.  I can get to all of the bolts/studs but two.  I cannot seem to easily figure out how to get to the two rear most bolts next to the bell housing/inspection cover.  I can get a 1/2 inch open end wrench around it from the side, but there isnt enough room to move the bolt enough to get it off.  if i have to remove the inspection cover/bell housing, how do i do this?  I have a pretty good understanding of mechanical stuff and have done almost all the work on my own on my jeep, however i really dont want to pay someone about 400 in labor to do this.  especially when its two bolts i cant figure out!
my jeep is on a 3 inch lift kit and hopefully i wont need to do all the unbolting i have read about in other posts/forums since i have a little more clearance.
thanks!!
thanks!!
