89cherokee
What could possibly be leaking oil in the bell housing? I've replaced the rear main seal and the oil pan gasket. I also replaced the "O" ring behind the oil filter bracket. Someone on the forum a while back had suggested that could leak. Well...that "O" ring had hardened and was leaking badly. The replacement was $.77. And it was easy to change...take out the long bolt and replace. But now the oil is coming out the bell housing....any ideas? Thanks
