well.. one thing with the hydraulic steering and the non-parallel tracbar, he is gonna have a completely different problem than we would.... with our steering, if they are not parallel, and we hit a bump, the geometry will force the pitman over and make us steer... but with the hydraulic steering, there is no give in the steering system, the hydraulic ram will keep the steering constant, so there will be no bumpsteer... BUT... it will limit his flex in the front... if the ram and the tracbar are not parallel, then it will form a virtual triangle out of the front end and will not allow it to flex much at all... and... since the draglink is replaced with a ram, which is variable in length, the relativity of the ram/tracbar angle will be constantly changing while steering, where as with a pitman/draglink setup, it would be constant.... i'm thinking that since the hydraulic ram would be self stabilized by the properties of the system, and it is fixed to the frame on a solid point, rather than a pivoting point, it could serve the purpose of the tracbar itself... and might be beneficial to remove the tracbar, which i see he has replaced with an adjustable, and may have it open for free movement while offroad
