Odometer gears??
robo83
Hey guys, I have a '93 wrangler that's lifted and got 4:56 gears, how do I regear or fix my odometer gears. Cause I started drivin at the end ofthe summer and k had 84000 miles on it. Now in a little under half I year I have 90300 miles on it and there's no way i've put that many miles on it yet. I don't drive much except back and forth to school and work. Is there Any way I can fix this?
Changing Your Jeep Speedometer Gear
Let me know when you determine what speedo gear you need, I may have one. There's also an adjustable speedometer interface you can buy from Dakota Digital that makes the speedo infinitely adjustable on the fly for about $80.
I think he's talking about how to change the actual miles traveled already... IIRC, that's illigal to do.
According to the chart on that link bounty hunter sent me, I need a gear number 52067639.
I just want to get It fixed so I'm not puttin double miles on my jeep
Unless you go from 28" to 40", it's not gonna be a drastic increase (most likely, 10% or less). And going to a bigger tire size will actually show LESS miles, not more (speed will be less on the speedometer); one rotation of the tire will cover more distance... So if 28" requires one rotation per yard, a 35" tire will cover 1.2 yards for every rotation (numbers are fictional just to represent the point!). So you would actually need to INCREASE the miles on the odometer.
My advise: leave it as is and fix the gear so that your speed and miles from now on are correct.
Felipe
Bounty hunter, I don't mind waiting if you think you have one that will work. I'm confused on what jfrabat was saying???
the whole tire thing sounds good, but my spedometer is tellin me im goin way faster than i really am, what does that mean?
