tosucowboy
Okay, I have an '89 YJ with the 4.2 It has the TFI ignition on it and I just swapped the coil for an MSD blaster, I just put a MC 2100 on it, it had a 4 barrel holly that was f-ing up and I just need it to drive right, so a lot was removed but I'm not entirely sure what. It ran fine when I bought it but when the ICM failed and I replaced it I started having problems. The jeep has been rewired with a universal wiring harness from painless wiring this happened last winter, problem was solved for about 8 months, so like I said, I have now changed the carb, thought I had everything set, and today it doesn't want to fire, granted it is around 8 deg f outside. I want to do the nutter bypass to get rid of the computer, i'm in Ohio so I don't need to worry about smog. I saw something where the procedure for it was on this site but I can't find it. I have seen different diagrams. I know to connect the purple to purple and orange to orange from distributor to Ignition control module, but nothing ever mentions what to do with the inputs to the starter relay, or if I just get rid of that.
any help with proceedure location would be much appreciated. I am seriously frustrated here, I am already about to have to replace the flywheel...again, from haveing to crank on this thing to get it runnning.
