hi all...first post ever !
i have a 2005 tj with nsg 370 6 speed with 43000k, clutch release bearing just went. clutch pressure plate and release bearing have been replaced but i,m not sure about my hydraulic clutch slave.
i noticed the slave extends to full stroke when installing, it doesn,t actuate the fork its not strong enough, but it does push against the
fork constantly,which makes me question the correct release bearing preload,
it seems to me the fork is and will continually keep the release bearing in contact with the fingers on the pressure plate.
shouldn,t there be a gap so the release bearing doesn,t turn all the time, only when engaging the clutch?
the slave does collapse, and the fluid does return to the bottle, it does actuate the clutch.There must be a spring internally to extend the piston, it allways extends to full stroke when not installed.
an ideas?
maybe this is why the clutch /release failed to begin with.
thanks
Dan
an ideas?
thanks
Dan
