K Kent New member Jul 20, 2003 #1 269000 I installed a 4" lift to my 77' CJ5. Once completed, I discovered a grinding noise when the clutch is disengaged, and the vehicle is coasting, and additionally noise at speeds greater than 25 mph. I'm at a lose for an explanation. Any ideas?
TerryMason Administrator Staff member Jul 20, 2003 #2 270000 Is the clutch linkage too short now because of the lift, and not letting the pedal go all the way down? I'm guessing that you installed a 4" suspension lift, did you do anything like lower the transfer case? Terry
