stevodango69
i have a 00 grand cherokee with a 4.0l in it i replaced the crank position sensor and it doesn't want to run. it will fire some times and when it does it missses really bad. other times it won't even start. took the plugs out number 3 and for cyclinder look like their not firing. changed the coil packs and no difference. could it be the crank position sensor it not spaced right it had a paper on it to set the gap figured that was right. could it be the cam position sensor. and some the gauges only work part of the time. the volt gauge doesn't work at all.
