i just installed a BL and MML on my jeep that had 4" of lift and 33's.
I took my horrible TC drop out and triple checked everything, everything is tight, and solid, however i now have some clunking sounds when in drive and giving alittle gas and letting off quick, it doenst make this clunk sound when in park and giving the engine some gas, so its just in drive. with or without a load cause i jacked it up and put in drive and same thing happens.. have no clue where to start, it sounds as if its coming from back of motor, trans, or transfer case area.
I also noticed some mild-to heavy vibes around 60mph, which i thought by adding the MML and being able to take out the TC drop would have solved any of that.. Also i didnt even take the TC drop all the way out, i left some small spacers in there just to be safe, should i add some more, take it all out??? need some ideas, i have tried to find this for 2 days now?? thanks
