Need YJ Soft Top windshield brackets
joeylead
I am gathering all the parts for my soft top, I have everything I need except for the bracket that bolts between the windshield and rollbar. This is for a 92 YJ with a factory top for full metal doors. I dont even kow what it looks like, so if someone can even just take a pic that would be helpful too. Is is this, or is this for a top with half doors?
Jeep YJ Wrangler soft top brackets | eBay
That looks like the bracket that holds the frame pole just above the door latch. The piece I believe your looking for is a flat triangular shape (that goes between the roll bar and windshield brackett) with a 90 degree tab (where the frame attaches). I will try to get you a pic. Also I can check to see if I have an extra set at home.
The YJ factory softop was never designed for full hard doors and I know of no door surround bracket that will work. The YJ softop door opening is square for the soft door upper.
They look pretty similar to what I think i need. I will compare it to the picture that i do have in the manual from the top that came with the jeep. its for a different application, and Iamnot sure if the part where the pole attatches to is the same.
There were 2 different types of tops, one was for the model with full doors. I attatched a link to the parts list, unfortunately I cannot order it as they are all discintinued.SOFT TOP HARDWARE WITH FULL HARD DOORS WRANGLER, YJ. Fits: 1992 JEEP WRANGLER 4.0L I6 Power Tech, 5-Speed Manual | FACTORY CHRYSLER PARTS=
