Need Info on lift springs
jeepin916
Active member
ready to buy new springs for the good old jeep hehehe, i currently have 4 inch springs under there now, and they dont really seem to be sagging other than the rear but i want to put new springs under her while im putting the axles under her. im looking at the Rubicon Express springs either the 5.5 or the 7.5 inch coils
i will have lots or weight added to the jeep including new bumpers winch front and rear and a tire carrier and also a full cage,
i dont wan tto put th elong arm setup onto it at this time should i go with the 7.5 with extended lower control arms or the 5.5 with extended lower control arms?
should i go with adjustable lowers or the regular extended lowers that i currently have?
SYE kit will be installed so drive line angle wont be a problem, and i have pinion adjustment bolts for the upper arms. shoule i spend a little extra and get extended uppers? and adjustable lowers?
Sounds like your spending a pretty penny as it is. Might as well fork out the extra dough to get the extended uppers. If you're gonna do it, do it right.
C
If you go the route of 7+ inch lift, I would definatly go with a long arm That is if you ever plan on a little flex in the suspension. The longer arms will also reduce thing like wheel hop (which is not a biggie in a jeep) but also the pinion angle. I am unsure if just adjustable ctrl arms can solve this.
I wouldn't install springs any bigger than 5.5" without a longarm. Otherwise your control arms are near vertical, and that causes a lot of problems not to mention safety concerns.
if i put in a 4".. i'd still want long arm... but it certainly is fine without
Motor mounts ques
hmmm sounds good but i dont think i am ready to shellout that much for a long arm kit. its not the right time yet i want to have a small block in it when i put on a long arm kit, i do mostly highway now and when the jeep is done i might take it out once a week and thats it. think ill stick with 5.5 thanks everyone
every bit you go up.. the ride will suffer
Last weekend pics
I put the 5.5s in with just extended lowers and I got mad dw the sye fixed it for the most part but you will need new track bars. with the bracket.
coool thanks guys, i have extended lower arms but i will get adjustables and probably extended uppers, thanks for the info
