1065783
I just bought a 2002 Liberty limited two days ago, it has 18k miles. I have noticed two problems, one which concerns me more. The lesser one is that when the wheel is turned significantly (like for a real turn, not a lane change) the steering column area squeeks fairly loudly. If I repeadly turn the wheel it won't do it again. I have to wait and let it "sit" in a straight position for a minute or so, then when I turn it, it squeeks again. It does it for both left and right.
The other problem is that when the car is stopped and in gear, it stumbles a bit and you can hear and feel the engine missing or cutting out a bit. If you try to crawl slowly using the brake, like 1-3 mph the truck bucks because of this surgence in power. It seems even worse in reverse. Once it is moving, or the car is in Park, the problem stops, which makes me think it is "solved" when the revs go up a bit.
I'm taking it back to the dealer ASAP, but I'm sure some of you know more than the people at the dealer, so I wanted to try for some feedback first.
Thanks!
Jeff
Thanks!
Jeff
