Nasty ride
kingmega
need some hints and or tips. frontend walks or sways on road worse over bumps and turns have 96 xj 4.5 in lift adjustable arms and adjustable track bar lockers aussie up front ford 9" in rear on 33's i have no sway bar. would a sway bar help cure this problem could the track bar be out of adjustment this things kinda all over the road
sway bar may help would deff check the track bar but it may be out of alignment
i've pretty much checked everything nothing loose all bushing are good and tight front axle looks to be nice and centered have yet to try the sway bar waiting for disconnect links
You really shouldn't drive a coil sprung jeep without a swaybar in the front. Hooking a swaybar up should solve most or all of your handling problems.
