jarhead720
Alright guys I've got an 89 xj 4.0..the fuel pump wont work unless it is wired to battery or another hot wire..at the fp relay it has power on one terminal when ignition is on but doesn't have a 12v constant..it is the same for the pump it has power at the pump but when cranking power drops to zero..the fuel pump will not kick on at all unless jumped...I tried jumping relay terminals 87 and 30 if I ain't mistaken and it still won't kick on..I no that it has a fusibe link by the starter relay.just don't know which wire..also the wires coming from the starter relay are about melted..in conclusion can anyone point me in the right direction here..I have to drive 40 miles one way to physical training twice a week and really need this fixed asap..also before I had the fuel pump jumped from the relay and wired into the ignition worked great until the day before yesterday the fuel pump went out..the guy I had put the new one in said that you can't wire it to the ignition because it will burn them up is there any truth to this?...thanks guys
