Its a jeep
My Cherokee has gone through 6 O2 sensors in about 8 months. The trouble started when a few brackets broke off of my exhaust, causing the wires of the downstream sensor to rip off. The upstream burned out shortly after. I replaced both sensors with Bosch sensors, but the check engine light came on days later, for the new sensors. I ignored the problem for a while, and the engine light would go off for 3-4 days every other month. I returned the bad sensors and got two identical ones. I also had to replace the Throttle Positioning Sensor because that went bad too. About two weeks ago I replaced all the sensors. The next day the engine light came back on for the downstream sensor, then a day later the Jeep threw a code for the upstream sensor.
The recurring codes I've been receiving are:
P0135, P0138, P0133, P0132, P0131, P0136, P0137, and the code it threw for the TPS was either P0121, or P0122, I can't remember.
I would be really appreciative for any solutions, I live in New York, and I cannot renew my NYS inspection because of the emissions test.
