Turbogus
Active member
Howdy Gang,
Well I finally broke down and got me a fan shroud for my '78 w/360. A word of caution, the new Omix-Ada needs relief ground in the bottom for clearance of the lower rad. hose and drain petcock.
My question is has anyone ever tried mounting their electric fan to the shround itself? I'm thinking of using plumbing strap.:?:
I've found that my mounting the fan to the radiator had torque damaged one of the cooling tubes, so trying a different location~also optimal performance of the fan may be attained if it's nearer the open end of the shroud I think.
Thanks and a lift of the lynch lid for any responses
