mattilus2121
Ok, once it got cold where I'm at my jeep has started having water in the oil. I changed the head gasket, now all cyls are at 150+ psi, pressure tested the radiator, its fine. My coolant level has stayed the same. it has a weber carb and the tube to the intake is blowing air into it. I have been at this for awhile nwo and when the temp is above 40-50 it is fine. Help
