Atlwheeler32 New member Dec 26, 2012 #1 I just received a used copy of the 87-95YJ Chilton's repair manual for my "new" YJ and it's missing pages 1-28 and 1-29. If anyone can copy and send these in .pdf format it would be greatly appreciated! Thanks in advance!
R Ronan New member Dec 26, 2012 #2 I've attached the requested pages from my copy. Hope this helps! Attachments Chilton I28 I29.pdf Chilton I28 I29.pdf 241.9 KB · Views: 243
JPNinPA Well-known member Dec 26, 2012 #4 You will find the factory service manual much better. The chilton is sometimes wrong or not enough detail. If you look you might find a PDF version.
Turbogus Active member Dec 27, 2012 #5 JPNinPA said: You will find the factory service manual much better. The chilton is sometimes wrong or not enough detail. If you look you might find a PDF version. Click to expand... X2 ! and the same goes for Haynes
JPNinPA Well-known member Dec 27, 2012 #6 Turbogus said: X2 ! and the same goes for Haynes sucking as well Click to expand... Fixed it
