FAHRENHEIT451
When do you know it's the Master Cylinder? My brakes work buttttt......the brake pedal has some play before I can sense the brakes are engaging. It is not the same squishy feeling that you get with air in the line, or is i?. That instant response you get when you just start touching your pedal is not there. I just purchased this 2005 Liberty with 80k miles on it. I guess I'll bleed all lines and if that doesn't work then replace the Master Cylinder?? Any ideas?? The Booster??? What is the proper process of elimination?
