J Junkpile New member Jan 2, 2005 #1 RE: Avatar? Anyone happen to know the spline count on the shafts in the rear D70 from a 1967 M715? How about the front D60? Stubs?
mingez New member Jan 12, 2005 #2 I found these numbers on another site: inner axle diameter: 1.50" inner axle spline count: 23 stub axle diameter: 1.375" stub axle spline count: 21 inner and stub axles both neck down between splines and yokes, like Ford d60 axle joint is the same as d60, no tracta joint diff is a Dana Powr-Lok gear ratio: 4.88:1 **Check out these links to POR, got the numbers there. (Careful, you know POR, flame and vulgarity all over the place. ) http://www.pirate4x4.com/forum/showthread.php?p=3085401 http://www.pirate4x4.com/forum/showthread.php?s=b7f0fcc209150f97f71f81f019db0c73&threadid=83596 ***Here's an m715 site: http://www.m715zone.com/ There's some good info on there. Man, sure seems like a lot of work. I may not know the answers you seek, but I can search the internet like no other! :wink:
J Junkpile New member Jan 12, 2005 #3 Thanks Mingez. I can get a set of those axles pretty cheap, but the closed knuckles and coarse splines kind of make them less attractive.
