Loose Steering Column ... Help!
Chris1231
I have 85 Cherokee. The steering clomun is extremely loose. Is there a way to tighten it or do I need to replace the column all together?
1040495
You can tighten it up. You need to remove the steering wheel lock plate, turn signal switch and ignition lock cyl. I think thats it. There are 2 inverted torx head screws, tighten em up.
