Long shaft speedo gear dana 300.
Jorns
Anyone know where i can get a long shaft speedo gear 22 teeth for my Dana 300?
I have a cj7 with axel rate 2.72 on the axels and need to correct my speedomether after putting 33 inch tires on it. My original speedo gear count 24 teeth.
Hi,
how do you got this fixed ?
Having the same problem. A ratio of 1:2,73 and 33" wheels.
Would need also 22 tooth speedo gear
Hi,
Kerry at transmissioncenter.net says that a long shaft 22 teeth isent available. The 24 tooth is the smallest ever made with long shaft.
I have bought a ratio adapterto connect between the transfer and the speedometer cable. I ordered the 11% speed up rate (#54RA2).
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4 ratio adapter
I havent tested it yet thoug because i ordered it yesterday, and i live in Norway so it will take som time before i have it.
