long arm bushings
lowater
i have what looks like rough country long arms and was wondering if anyone knows, where i can get the axle end bushings? (i already have the x flex rebuild kits) sherrly someone on here has bought these some where? i would like the stiffer ones that hold up and RC only has the soft rubber. hope someone can help. i have searched. thanks
Not sure they make a nudging out of a stiffer material that fits. Most bushings inserts are specific to the casing so to change it you would have to replace the caseibg which I assume is welded on. If its an oem style bushing someone may make a stiffer one but in my experience its not needed and will also decrease your ride quality. The softness of the bushings absorb a lot small road bumps.
