Has anyone ever replaced the locker indicator switches on an 05 Rubicon? They screw into the top of the differential housing and when the locker is engaged, the locker plate pulls the switch which turns the light on up on the dash.
We replaced the rear seals and after reinstalling the carrier, it seems that the locker indicator switch is pushing on the locker plate and partially engaging the locker. I unscrewed the front diff locker indicator switch and it came out super easily. When I tried to replace it, now the front locker is also partially engaged. There has to be a way to replace these switches without removing the entire carrier assembly.
Any advice?
Any advice?
