hey gun nuts
Was sold but buyer backed out due to travel time to pick up
for sale
a Reman 258 six cyl engine, was in a 1983 cj7, but is a direct replacement for 76-91 CJ's, Wranglers, and Cherokees. It has only 18,207 miles on it. It runs perfect, and has no known problems or oil leaks. It was pulled from my jeep in the end of August. It was bought and put in the jeep 9 years ago and the jeep sees only minimal summer driving a couple thousand miles a year. Motor runs real strong and has lots of power
Engine is complete except for a carb
When I say complete you get everything water pump, oil pan, new (Aftermarket)aluminum valve cover, distributor(performance aftermarket), alternator, starter, power steering pump, flywheel, pulleys, belts, motor mounts,intake and exhaust manifolds(with no broken bolts) radiator hoses all vacuum lines, good used Clutch, pressure plate, T4 Bellhousing i mean everything except the carb,
Plus some extra parts
this is well worth the money and would be a good setup for someone with a 4cyl wanting to swap to a 6cyl since it is complete
$500 obo
Email me direct at jasonvess@yahoo.com
for sale
$500 obo
