Lift?
stradivaribe
I have 3'' coil springs up front, 2'' leafsprings in the back. I plan on getting more lift in the rear with longer shackles, but what can I do for the front without buying taller springs? Can I use aftermarket spacers with Procomp springs? If so, what kind should I get? And how tall of a spacer can I get? Thanks.
You can use 2" budget boost spacers in the front, many are actually 1.75" tall. You can also use extra stock coil isolators, they're about 5/8" tall. The stock spacers are stackable with each other and with the 2" spacers to customize your amount of lift.
Keep in mind that the higher you go, you'll need longer control arms to correct your steering geometry and wheelbase. You're control arms will become more vertical as you go up, which is why many convert to a longarm kit.
