Largest Tire Size
If the 1.25" coil spacers are installed, will 31x10.50 fit?
no, go with the 1.75" spacers (commonly referred to as 2") and you can fit 31s. but it is going to depend on the make of the tire, some run taller, some wider, so you might have to trim a little bit inside the wheel wells and the part of the bumper in front of the wheel wells. again, minor trimming, nothing serious, but with a 2" budget boost you can fit 31s.
They are 2" spacers if you leave the stock isolators in place. At least the ones that come form Rocky Road Outfitters are. I know this has been covered before, but I would want to know what they measure before buying.
Yeah, a 2" spacer would clear 31's. Make sure you get a front end alignment after installing them ;)
