Allen's Offroad
$105.49 shipped in the lower 48 US. California residents add $6.33 sales tax.
KIT INCLUDES:
2--14" of 1.5" X .25" wall DOM tubing
2--3/4" X 3/4" Bore Heat & Cryo Treated Chromoly Heims
2--3/4" Tube Adapters (1" Tube ID)
2--3/4" Jam Nuts
4--3/4" to 1/2" Stainless Steel Misalignment Spacers
This kit is designed for two things. The first is it comes with 2 pieces of 1.5" x .25" DOM tubing to sleeve over your existing upper link arm and make it alot stronger than stock. The second is it comes with two 3/4" heims to replace the upper bushings and allow your suspension to flex more than it had before.
Notes: The OD of your stock link is powder coated and might need to be ground off a little to slide the DOM over it.
Welding is required and should be done by a professional.
Here is what you start with and how to get it done!
You replace this bushing end with the Heim Joint...
And you put the pieces together and end up with this!
Weld'em and get more articulation and less expectation of bending them
If yours are already bent just cut them off shorter. The tube you use to replace the factory 1" x .120" wall is 1.5" x .25" wall and almost 3.5 times stronger so cutting them off shorter would never be a problem.
PM me your name, billing and shipping address, phone number, email address (for PDF receipt) to order. I will call you for CC info.
Thank you very much. I am truly grateful for your business. When replying please include all previous messages in PM (keeps a running conversation).
Namaste,
Allen
KIT INCLUDES:
2--3/4" Jam Nuts
Namaste,
Allen
