jeeping husband 1.0
_(OIIIIO)_Jeeper
OK heres anther shanghi'd funny...kinda long....but funny
You've ALL seen the Husband and Girlfriend 3.0 jokes.
Here's Jeeping Husband 1.0
Dear Tech Support:
Last year I upgraded from Boyfriend With Jeep 5.0 to Jeeping Husband 1.0 and noticed that the new program began making unexpected changes to the accounting software, severely limiting access to wardrobe, flower, and jewelry applications that operated flawlessly under Boyfriend With Jeep 5.0. No mention of this phenomenon was included in the product brochure. In addition, Jeeping Husband 1.0 deactivates many other valuable programs such as DinnerDancing 7.5, CruiseShip 2.3, and OperaNight 6.1 and activates new, undesirable programs such as Jeep Buddies Night 1.3, Saturday Four-Wheeling 5.0, Mechanic 2.4 and JeepPartsEverywhere 4.5. Conversation 8.0 no longer runs correctly, and invariably launches the Last Weeks Jeep Adventures browser version 3.1. DiaperChanging 14.1 or HouseCleaning 2.6 doesn't work, especially on weekends, either. I've tried running Nagging 5.3 to fix Jeeping Husband 1.0, but this all purpose utility is of limited effectiveness.
Can you help please ?!!!!
Jeepless Jane
Dear JeeplessJane:
This is a very common problem women complain about, but is mostly due to a primary misconception. Many people upgrade from Boyfriend With Jeep 5.0 to Jeeping Husband 1.0 with no idea that Boyfriend With Jeep 5.0 is merely an ENTERTAINMENT package. However, Jeeping Husband 1.0 is an OPERATING SYSTEM and was designed by its creator to run as few non-Jeep related applications as possible. Further, you cannot purge Jeeping Husband 1.0 and return to Boyfriend With Jeep 5.0, because Jeeping Husband 1.0 is not designed to do this.
Hidden operating files within your system would cause Boyfriend With Jeep 5.0 to emulate Jeeping Husband 1.0, so nothing is gained. It is impossible to uninstall, delete, or purge the program files from the system, once installed.
Having Jeeping Husband 1.0 installed myself, I would suggest you read the entire section regarding General Partnership Faults (GPFs). This is a wonderful feature of Jeeping Husband 1.0, secretly installed by the parent company as an integral part of the operating system. Jeeping Husband 1.0 must assume ALL responsibility for ALL faults and problems, regardless of root cause. To activate this great feature enter the command "C:I THOUGHT YOU LOVED ME"
Sometimes Tears 6.2 must be run simultaneously while entering the command. Jeeping Husband 1.0 should then run the applications Apologize 12.3 and Flowers/Chocolates 7.8. TECH TIP! Avoid excessive use of this feature. Overuse can create additional and more serious GPFs, and ultimately YOU may have to give a C:APOLOGIZE command before the system will return to normal operations. Overuse can also cause Jeeping Husband 1.0 to default to GrumpySilence 2.5, or worse yet, CJ 6.0. CJ 6.0 is a very bad program that causes Jeeping Husband 1.0 to create SmallJeep 1.0. You will find very little space within this program and Wife 1.0 no longer has enough room to run during JeepTrips 2000. You will soon be running WhereDoISit 5.3. Save yourself some trouble by following this tech tip!
Just remember, the system will run smoothly and take the blame for all GPFs, but because of this fine feature it can only intermittently run non Jeep related applications. Jeeping Husband 1.0 is a great program, but if it doesn.t involve Jeeps, there is limited memory available and cannot learn new applications quickly. Consider buying additional software to improve performance. I personally recommend PowerTools4Gifts 3.0, Lingerie 5.3 and Patience 10.1. Used in conjunction, these utilities can really help keep Jeeping Husband 1.0 running smoothly. After several years of use, Jeeping Husband 1.0 will become familiar and you will find many valuable embedded features such as FixesBrokenThingsOtherThanJeeps 2.1, Snuggling 4.2 and BestFriend 7.6.
A final word of caution! Do NOT, under any circumstances, install MotherInLaw 1.0. This is not a supported application, and will cause selective shutdown of the operating system. Jeeping Husband 1.0 will run only Long JeepTrips 5.2 and Longer JeepTrips 9.3 or GarageWork 2.5 until MotherInLaw 1.0 is uninstalled.
I hope these notes have helped. Thank you for choosing to install Jeeping Husband 1.0 and we here at Tech Support wish you the best of luck in coming years. "We trust you will learn to fully enjoy this product!
funny.....jeeper that you selling motor stuff on ebay?
Personally, I am thoroughly enjoying Jeeping Husband 1.0- best program yet. On another note, we are about to have our resident welder (son) make us a coffee table out of two CJ grills we purchased earlier..... he's going to use 4wd parts he buys at a local junk yard for $.10 a pound to hold it together- should look really cool- pictures to follow!
stock fog lamps
That's why you need to find JeepGirl 2.5, preferably bundled with Mudding 1.9b, and RusticCamping v.2 (still in beta test mode) :)
