jeep chic with drive shaft problem
aaron
have 4 inch super lift and want to add 2 inch body lift to accommodate larger tires.also putting a 4.2L in with a NP 208. what I want to do is remove my transfer case drop that came with the suspension lift and actually raise the transfer case up into the body by having a low profile skid plate.(2 inches) intend to increase the height of the motor mounts as well to keep the drive line level. do need new drive shafts as well but how do you handle the angles on the drive shafts. I have seen pictures before of jeeps with skid plates level with the frame so I am quite certain it can be done but would like any and all info on a job such as this
thank you
660000
SYE .... Slip Yoke Eliminator ... If you get a good kit you will get the drive shafts and all... They will need the measurments of the shafts.
661000
np208 does not have a slip yoke or this one anyway so should local driveshaft shop handle problem without difficulty
