jacking points
kendrick_d
I am going to put coil spacers on my cherokee and I was wondering where the best place to put jack stands would be in order to drop the front axel. Thanks to the lack of a frame I am weary of just putting them under the body. Any advice would be appreciated.
Thanks,
Kendrick
RE: YJ TRAILER PICS
Right behind the lower control arm mounts, on the psuedo-frame.
ditto that... use the stock jack points on the unibody. I'd put it on stands, remove wheels, then put a floor jack under the axle before you let it loose
