Yes... green to the Neg. coil, and the orange and purple should be twisted together at say three spirals per inch and should be shielded from any other wires along the entire path to the distributor.
Somewhere along the way ground the black wire between the connectors of the Ignition module and the distributor. I suggest you ground it to the block, if you also install a dedicated ground from there to the firewall and be sure that the battery neg. post is grounded to the firewall.
Assuming that your using the wires from firewall connector;
The red from the Ign. Module will connect to the #10 red wire from the run position switch which also supplys power to the positive coil and the I (ignition) on the Starter Solenoid whips or pig tails via a faint red resistor wire.
The white wire from the Ign. Module would connect to the blue wire running from the S (switch) on the Starter Solenoid and the start position switch. Typically this blue wire is spliced into one of two #14 white wires grouped together at the firewall connector just below and to the right side of the #10 red.
A bit of caution concerning the run position switch. If you leave this switch in the run position while the engine is not running it will cause both the Ignition Module and the coil to overheat and the module will soon be toast.
