1043206
89 YJ 2.5L 4-cylinder.
I go to the movies on friday. when I come out and hop in the Jeep, I turn the key and the starter is turning the engine, but it won't fire. I can tell it's not the battery cause the starter is flying (da-na-na-na-na-na-na, not slow). so I stop, give the gas pedal a kick, try again. same thing. then the third time, it starts right up. drove 5 miles home, no problem. put it in the garage, turned it off. tried to start it again. same thing. sometimes, it will fire on the first try.
So I replaced all the spark plugs, put in new plug wires. The dist.cap and rotor are less than a month old, so I just took them off and inspected them. They look like new, no cracks, erosion, or anything. I even changed the oil & filter and the inline fuel filter. All of this had no effect.
Could the problem be a bad cylinder that's not firing? The firing order is 1-3-4-2. Does that mean that it always starts on 1? what if 4 is bad and it tries to fire first, does the cam shaft spin and perhaps land on a new starting cylinder like a revolver and russian roulette? I've gotta buddy that owns a machine shop so I'm gonna get him to do a compression check on each cylinder. Should I replace the Dist.cap anyways?
HELP!
HELP!
