1046830
i just wanted to to let you that i drilled out the venturi tube out like you said to do in your article. the one problem that i had was that i could not find a drill bit small enough. but i asked one the technicans at my job and he had a carb drill kit that he had picked up at an auction. he let me use it. i was a little nervous at first to do something like that,but at the first of the year i will be buying a weber carb. so i figured i would try it to see if it would really work. wow ....what a difference?thank you for the insight . fred[addsig]
