How to know if i have abs
Have you put you VIN into the decoder on the site? I learned a lot that I didn't know about my Jeep.
The quickest no hassle way is.... next time it rains drive at 30 mph and stand on the break if it locks up into a skid you don't have abs.
Lol I don't think he will be driving till he replaces his front axle
Look at the axle and if you have a wire the size of a pencil going to each wheel attached to the knuckle then you have ABS. Also look around the master cylinder and see if you have a pump. Even if you find an axle without, unless it's a vacuum disco axle, you can swap shafts and sensors over. Most shafts after around 96 have tone rings anyway so all you'd have to do is bolt the sensor at the end of the wire to your knuckle.
the wire on the caliper area is the easiest way to tell. there should be a notched ring the sensor that wire goes to reads off of also. follow the brake lines from the master cylinder and if they go into a weird box thing and then out to the rest of the jeep, that is your abs pump. if they just go straight from the master cylinder out to the wheels then you don;t have it
hey, according to google, your front axle and the axle from a grand cherokee zj, are hte same
if you ever forget whether you do or dont, might just be easier to lift your shirt and see if you have abs or a keg xD
Don't ABS Jeeps have a dashboard light that comes on when you start your Jeep?
They all have the light and some even come on when you first start it even when they don't have it.
A visual always helps! "How to know if I have abs?"
That was very kind of you to pose for us and put your body on display as a visual aid. Thank you very, very much.
