Hockeyfrog
Hi,
Sorry i rambled in my post. basic question is How tight should my serpintie belt be. Or actually how Loose ? thank you very much. Read on if you wish.
I have a 93 cherokee that I just had the priviledge of replacing the water pump on and for fun had to remove 1 fan, power steering pump and tensioner assembly and a few other odds and ends just because some genious thought the water pump needed to hold a power steering unit. All went ok except for bad threads on the water pump that had to be retapped and a stripped bolt someone thought shouldn't be fixed when they replaced the power steering awhile back. But now i am getting what i think is bearing noise from atleast the Alternator I loosened it and it is better but not sure how lose to go. It seems loose enough but maybe not if i am still getting the noise. The car sat a week while i fixed the water pump but don't think that is it. I can push the belt down about 1/2 a inch and seems tight but also wouldn't want it looser but really don't know. Should i keep loosening it till all noise stops ? then try the AC to see if it squeeks? Or is their a standard i need to know ?
Thank you all in Advance for reading this post and helping if possible.
Have a great day
Hockeyfrog
Have a great day
Hockeyfrog
