how much lift would i need?
jeepmaster
do any of you know how much lift i would need to clear 35X13.50X15 on a 93 YJ? is it gonna be 5 inches or less so i can stay Jeep Jamboree legal? thanks ~ master[addsig]
1046874
I would think you need at least 5". check out this Chart from jeepyj.net. [addsig]
1046882
you can just get away with 5" but under hard flex you will rub ... even the guys at skyjacker with that 6"mono leaf lift said you would have to have a 1" body to help out.... good luck
1046937
it's best to have atleast 6 inches for 35's.....the 5 inches will put the tires pretty far up into the fender well [addsig]
1046944
well when you're talking 5 or 6" of suspension lift i would personally go with the procomp CSC stage 2 kit, i think its overall 5" of lift, but the coil springs are sweet as hell i've got a budy who just did the lift, its a good lift, and he clears 35's with plenty of articulation and wheel travel[addsig]
1046962
I've got a 90 yj on 33x12.50 and i only have 3.5 in lift but they rub a little when i turn the wheel all the way. [addsig]
