How do I remove factory decals?
hoobness
How do I remove the decals all over my jeep? Acetone?
I noticed a minute ago that wth the new flares, the decals make it look pretty bad. Although the drivers side rust holes dont really improve anything. They just give it character.
But anyway, how do I go about removing the factory decals?
I want to say use a hair dryer to heat it up but I am not positive about that
#'s on my new (to me) axle
Yep, a hair dryer and a razor blade to get it started. You will also need some adhesive remover for later, pick up something that wont damage the paint.
Depending on how old your paint is you may have to buff out the paint. The paint behind the stickers is brand new and the older wethered paint might not match up. gl
Lighter fluid has always worked the best for me. just get a corner started and let the fluid soak in. then the adhesive will stay on the decal and not the paint.
Rent a heat gun for about $20 you'll be done in 10 minutes, then clean residue with goof off
goof-off and anything else like that will scratch the paint.
I would use a hair dryer and then a little polish to get the left over stuff off.
