Hot Floor Boards
Deerhunter30
I'm having a lot of fun tinkering with my 1983 CJ7. I have only had it a week and I have improved it quite a bit without spending too much money. I have a hard top, full doors and AC. I have spent some time trying to seal up the jeep to keep the hot air outside and the cool air inside. I live in Houston and with 90-100+ degree summers, AC is nice to have. The one thing that I have noticed is that the floor board on the driver's side is VERY hot due to the exhaust. Is there anything that I can do to help with that?[addsig]
1070919
Do you not have the Carpet. the TJ carpet is supposed to be an insulator for hot floorboards. Maybe you can get that and cut it to fit your CJ.[addsig]
1070921
I think most CJs have that problem... atleast I know mine does. Its the heat from the catalytic converter that gets the floor so hot.[addsig]
1070926
Under the STOCK late cj floor mats there is normally a tin foil like material that is there for insolation.If you dont have this material your floor will heat up like an oven. :wink: Sully[addsig]
1070929
Build or go to the junk yard and rob a heat shield of one of the jap cars. Just a simple light weight piece of metal between you and the exaust will help a bunch. tug[addsig]
