CalebJns
What we are working with...
1999 Jeep Grand Cherokee Laredo...4.0L Straight 6...223,000 miles...2WD...
Been a long day, and mentally my mind is fried...while heading home this evening I found a few things that aren't working (pretty much I was drained and fiddling with stuff trying to occupy my mind...)
1. Physical Horn isn't working...the "horn/beep" when you lock the Jeep works, but not the Physical Horn when pressed...
2. Cruise Control doesn't work...the green light comes on when the key is turned on initially, but when driving and the cruise control is pressed nothing happens...
3. Noticed this evening on the way home, that I have the "extra Radio controls" on the back of the steering wheel (right behind the cruise control buttons). These don't work either...I looked through the manual, but couldn't find any reference to a fuse I could check.
Do all 3 of these have the same fuse? Anything in common other than the steering wheel? And Location?
Thanks for the help...
