Anyone out there do the Nutter Bypass on their YJ/CJ? I'm getting ready to do it soon and I have the instructions in front of me but there is just one thing I'm not sure of and that's setting the timing. Normally, I set the timing at 9 degrees BTDC at 1600 RPM (hose disconnected and plugged). Now, after I Nutter the ignition, (rewire the distributor to bypass the computer) the instructions simply say to set the timing at 8 derees BTDC. Should I set it at 8 BTDC at idle speed (approx 700 RPM) or at 1600 RPM??? Any help before I screw up is appreciated. Thanks..........
1988 YJ with 4.2L engine. Soon to do the TFI upgrade as well.
