PoliceMonkey161
Hello All,
Ok, so got the steering issues worked out....Thanks again to everyone! Now it seems the rear is leaking differential fluid out of the brake plate/axle bearings. I had this problem orginally when I bought the Jeep and up graded to one piece Superior Axles. However, I had the local shop do the work. And low and behold, it's now out of warranty.:shock: After becoming confident in my repair ablities since completing several tasks on my own..... I turn to you all, my friends, for help.
I noticed a couple of weeks ago that a small amount of bearing grease was coming out of the little vent hole at the end of the axle. Took off the tire and drum, but all looked OK inside. Today I was under the Jeep retightening my frame bushings after the recent install and noticed what looks like diff. fluid slowly leaking from the same hole. Removal of the wheel and drum showed contamiation of the brake linings.
Any ideas what part or parts I should be looking at?
Thanks again,
Thanks again,
