1068053
To tell if a fuse is bad,you take it out of the fuse box,look at the fuse,(it should be see threw).There is a little bridge and there should be a little metal peice inside,if it is broken or seperated from the other side of the bridge,the fuse is blown.To avoid blowing fuses dont plug in wet connections to each other,like fog lights that were diconected,I blew a fuse that way and learned the hard way. Hope this helps. :wink: Sully[addsig]
