1056953
last night I went to the store, I noticed that the clutch pedal seemed to have a little more play to it then it used to, :-? this morning same play and after about 10 minutes of driving, I couldn't get her into reverse without grinding alot. The fluid level was very low, topped it off, drove it, seemed better, now it seems the same as before the fluid top-off (although the pedal is still loose maybe: 2") but the fluid is ok... interestingly, I had checked the fluid 2 weeks ago for the first time in a looong time and it was ok (yes I put the cap on straight :-D )I checked under and around, cant find any leaks even around the bellhousing. I've never had serious clutch problem, so I'm unsure where to look first.
I sure hope this is an easy one... cuz its cold here in boston, I dont have a garage & a new job to start on monday! [addsig]
