Hello from Southeast Kansas
Annie07
I am at my breaking point with my 07 Jeep Wrangler.... If you have experienced the death wobble you will understand. 😆🤪
Welcome!
DW could damage many steering and suspension parts.
Start with replacing the track bar. Use the largest bolts to fit through both sides. The idea is to take away all play in this component. From stock the bolts are too thin diameter. Tighten to spec.
Then do a dry steer test to find any failing components like TRE’s, ball joints, bearings or control arm bushings.
