hi
my headlights go off after being on after about a minute, then come on then go off .... they do this in low beam setting and high beam won't lock unless I hold the dimmer , I found some kind of module mounted to the kick plate under the steering wheelunplugged it and was able to create a bypass for the headlights and they work the way they are supposed to except via normal headlight switch btw headlight switch is new. I mounted a high amp toggle just under dash, so I have headlights lol. but if I leave it (the toggle switch) in the off position the headlights do the same thing on off on off off oiff. toggle in on position turns on headlights only no matter wheather normal headlight switch is on or off, some one suggested a headlight delay module ( the one that turns your lights off after you leave the car, but 2 things in that regard where is it in a 96 cherokee(XJ) country and where can I get a replacement.
