1053583
Well today I decided to get off my lazy butt and work on my jeep (95YJ) some. I bundled up some loose wires, fixed a leaky vacuum hose, and did some sealing on my York on board air system. There was leak right at the compressor output so I removed the two fittings and put new rubber washers in there. Well a little later I decided to go for a drive...I pull out of the driveway and get a bit down the road and GRRRRRRRRRRR I get this noise....it sounds awful and is coming from the engine compartment. Oh *%^$....what now. My mind races with the thoughts of bent rods or blown valves.
Anyway I head back home and try to determine the cause of the sound. I started the engine and moved the throttle to see if I could recreate the sound...it only seemed to happen around 2K rpm and stay between 2K and 3K. It was a loud sound too...had me totally baffled. It seemed to be coming from the valve cover at first...but I eventually traced it to the York compressor. "Well maybe the pulley or clutch is bad"....so off they come...noise still there. After looking at the compressor for a while it finally dawns on me...I notice that the little metal crankcase filter that I use to filter the compressor intake was wedged under the radiator support rod....sure enough....once repositioned the sound was gone.
I breathed easy once again. I guess its just a jeep thing...maybe even I don't understand hehe.[addsig]
