1059064
I have a 95 YJ 2.5 AX5. Recently, 5th to 4th gear changes were clashing.
Got the clutch master pump changed and everything was hunky dory.
A month later, I've been having gear clash from 2-3, but only at high rpm changes, ie at 3,000 and above.
If I have to rev it that high, I've got to press the cluth and lets the revs settle below 2,000 before changing smnoothly..
No clashes in other gears, even at high rpm. I have 110,000 miles on the clock.
What's the problem?
What's the problem?
